In trying to fix the front end clunking and severe toe-in I discovered the Right front axle pivot bracket is broken. Does anyone know where I can get a new one? I don't have much time to do the junkyard thing.
Ask around on this and powerstroke forum and you may find one from someone who has done a lift. I finally got rid of my factory drop brackets in my last dump run (a year after I did the lift) so I can't help you. You should find plenty of them in junkyards though; I believe Dana 44HD and Dana 50 use the same bracket, but that Dana 44 (F-150 and Bronco -- with coils rather than leaf springs) use a different one, so you should be able to get it from any TTB F250. Super Cab models have Dana 50 while standard cab came with Dana 44HD.
brackets are diesel specific i learned that the hard way well 50 specific i think the cc gassers had 50s but you cant use 150 or bronco ones the whole axle is different it sucks arms are different lengths
but junkyard or a lift is the only way i can find um easy round here but it sucks to pull them but i know a diesel chassie with no motor in it i could pull um from should be easier
