1 - 8 of 8 Posts
If you don't run in 4x4 much, You may want to try engageing the front hubs and going for a drive to see if they will dry up first.
When I pulled mine they looked perfect, I think they just got dru and if I had done that the leaking would have went away.
Tim -
If you please, email a copy to me as well at [email protected]
Adam -
My truck has 4.10s and 315/75/R16 Toyos (35", actually 34+); I recalibrated the speedo and am now off about .1 miles in 100 miles (no kidding), so it's pretty accurate. I'm doing 2100 or so at 70mph, 67-68 at 2000rpm. I'd say your door sticker is correct. Kinda makes you wish you had 3.55 gears, eh?
Josh
I did this and it worked, no more leak. Of course, I checked/filled the diff first!
Thanks for the suggestion, and thanks for all the help and data from everyone else.
Hey Adam I have a factory 88 manual that covers it when you need, I can copy pages or get it to you since you are close.
Russ
1 - 8 of 8 Posts
