Hi All -
I've got an alternator issue that I could use some help troubleshooting. Here is the long story:
Last summer I installed a new high out put alternator (DC Power) on my 2006 F350, complete with the upgraded wiring kit.
A few months ago, I went to drive the truck and noticed the batteries were pretty low. I had been doing some work on the radio recently and had the truck on/off several times so I figured that was the reason. It did start up, however I then noticed the battery light on my dash. It seems that the in-line 250 amp fuse that comes with the wiring kit had popped. I am fairly certain this did not pop before, I think it happened at that point.
I replaced the fuse, checked the wiring, and went on my way. All seemed well. The truck then sat for a few months as it doesn't get used much in the summer. Upon driving it again, I noticed my alternator was not putting out enough juice. Edge insight was showing around 12-12.2 volts. I popped the he hood and noticed the alternator was flaming hot and even smelled of some burning. I immediately called DC Power and they instructed me to send it back for repair.
In the meantime, I popped a ford OEM alternator out of my other 6.0 to put in this truck in the meantime. I have been driving the truck around with the OEM alternator for a few weeks with no noticeable problems. The voltage, however, does randomly show either 13.8-13.9V or 13.0-13.1V on my edge - not sure if this is normal or if it should always be 13.9.
At this point, DC Power called me to tell me they would not fix the alternator under warranty because the truck caused the failure. I am obviously angered by this but would like some opinions.
Thoughts?
Thoughts?
