Thanks everyone in advance... I've tried to read as many of the other posts as possible, but wanted to start my own here to see what I'm missing...
So this past Thursday, leave the house, and the first time the truck gets to about 45mph it stutters like its losing power, and I glance down and the Service Engine light is on... as soon as I lift the accelerator, engine starts to run fine and the light goes out. I pull in to a parking lot and it seems to be running fine. Get back out on the road, and as soon as I get to around 45mph again it stutters again, so I try to pull in to another parking lot, and as I'm doing so, it dies.
Now it won't start at all... turns over great, but no fire. No smoke. No movement of the tach.
So here's what I've done so far:
- Pulled every fuse to verify they were good.
- All the lights on the dash work, including the Wait to Start
- Replaced the CPS with a gray Ford one I had in the truck (new in bag)
- Verified good oil level on dipstick and HPOP (about 1/2 inch or so from top of HPOP)
- Replaced fuel filter, and with drain valve open, verified fuel flow through it when cranking
- Unplugged the ICP and attempted start - no go
- Replaced the CPS again with a newly purchased one from Oreilly (Borg Warner)
- I noticed what looks like oil that has leaked out previously from around the ICP, so I bought another but have not installed it yet.
- Reached down to see if I could move the end nut on the IPR, but it didn't budge (is that the tin nut everyone talks about?)
- Bought an AutoEnginuity scanner and it arrived today
- Initial codes were P1280 (ICP sensor circuit low), P1690 (wastegate solenoid circuit), P0603 (internal control module keep alive memory error)
- Cleared the codes, attempted to start it again and the P1280 is the only code that returned.
- Did a Key On Engine Off test using the scanner and P1280 is all it came back with.
So my first thought was "Replace the damn ICP". But from what I read in other posts, the ICP being bad "shouldn't" keep the engine from firing. And the truck being a 2001, the tach should move when cranking, correct? Cuz its not moving at all.
Its raining now, so I haven't done any other tests with the AE yet, and no, I don't have a fuel pressure gauge so I don't know what my actual fuel pressure is (I know I know). But if I'm not getting any tach movement and I'm not getting any smoke, I'm assuming the injectors aren't firing (or being told to fire).
So I'm open to suggestions on what to try next... physically and with the scanner. Thanks!
