At Autoglym we know scratches can be a car enthusiast’s worst nightmare. While you can take steps to minimize their occurrence, ultimately they are impossible to avoid.
Here is a quick overview of which ones you can fix yourself, and which ones may need professional help.
- For cars with light scratches and hazing on the clear coat, the paintwork will need polishing. Give your car a good wash with Autoglym Bodywork Wash & Wax, followed by a thorough run through with a clay bar to remove remaining contaminates. Once completed, apply Super Resin Polish to remove hazing, light scratches and restore gloss. While it has protective properties we recommend finishing with a coat of High Definition Wax or Extra Gloss Protection to further protect and enhance your high gloss shine from UV and environmental contaminations.
- Deeper scratches may be revive-able by polishing with a more abrasive polish. Simply wash your car thoroughly with Autoglym Bodywork Wash & Wax in conjunction with a Detailing Clay Kit. Once the paint is smooth and dry, gently apply the polish to the scratch. Take care to only use the polish in heavily affected areas. When you are happy with the results, simply apply Super Resin Polish to add a thin film that will help fill the imperfections.
If this process does not restore your paintwork to the desired level, we recommend you consult a reputable professional to machine polish your paintwork.
- For very deep scratches, no amount of polish will be able to remove the marks and as a result, rust could start to appear if the metal is exposed. For the best results contact a touch up specialist. There are a number of mobile specialists around who do very good work and you may be surprised at how little they charge.
- Scratches at deep metal stage need immediate attention.
Remember, it is all about being conservative when it comes to paint rectification, we recommend that you start with least aggressive methods and then work your way up until you are happy with the result.
Follow us
Autoglym Canada
Autoglym Canada Blog
Official Autoglym Canada Facebook
Official Autoglym YouTube
We are here to help you
If you require car care advice, or are unsure on the right Autoglym product to use, please leave a comment or visit www.autoglym-canada.com for more information.
