Drove a buddy to the airport this morning, and on the way back I hit an interchange that had a bump where the ramp starts. I hit it doing about 55mph and the truck started shaking violently, you could feel the steering wheel getting rocked left-to-right. I thought I was losing a wheel! Talk about "pucker up"! I was fortunate there was no one behind me or to the side of me, as I applied slight brake and decelerated to about 35mph and the shaking stopped. I pulled off the road and did a walk around the truck. Nothing appeared out of place, I checked the tire pressure to be sure, all 4 tires came back at 74psi (I run 70psi cold). I crawled under to check behind the wheels and see if I broke any steering linkages or axels bearings had spit out. No fluids, nothing out of place, bushings whole and in all the right places. I tried pushing/pulling on the front wheels to see if there was play in the wheels or bearings, no clunks or play. Couldn't find anything so I got back on the road and all was as if it never happened.
I've had an alignment done by Ford 1800 miles ago, they said it was perfect. I just had the tires rotated and balanced literally 2 days/150 miles ago. Tread wear is perfect and tread depth matches, one wheel was slightly out of balance by .5oz and they corrected it. The ride is smooth as silk as it gets for a 4x4 3/4 ton.
I'm not even going to bother taking it in to the dealer, after searching the web and here, it's just another issue Ford doesn't give a damn about. So I'll save myself their $200, just to tell you nothings wrong, diagnostic fee.
The list of Ford Fail is growing for my truck: Water Pump Failure (50k/mi), Radiator Leak (?50k/mi?), Death Wobble (51k/mi).
To Ford Service, don't bother. As you said with my radiator leak, we've got nothing to discuss.
I'm waiting for the coup de grâce for my poor F-250. My money's on water in fuel.
