Stock 2019 F350 6.7, I purchased this truck used 38,000 miles in April of last year. First instance of death wobble. Ford performed the recall / steering update. (Ford replaced the dampener, checked tires, tire pressure, etc.).
The second instance of death wobble the Ford dealer replaced the steering dampener with an after- market dampener. Third instance dealer changed / installed caster kit.
Now the fourth instance of death wobble. Passenger tie rod end and and Pitman arm tie rod end look bad (play when moving the steering wheel). 58,000 miles now on the truck. Dealer is checking on costs for parts.
Any suggestions on what tie rod ends I should buy? Motorcraft, Moog, other. Would I be better off to replace the bars and tie rods as an assembly? This is getting old and expensive. Thanks in advance.
