I just bought a deep mag hytec transmission pan for my truck, says it is 7 1/2 more quarts, instruction say to use a filter for a 4x4 truck, mine is a 2wd truck. is the filter on a 4x4 have a extension on it to set in the pan further? i do not see the difference.
4x4 pan is deeper than the 2x4 pan, so yes the filter is longer.
I havent figured that one out yet either, The 2 wheel drive pans are the same as the 4x4 pans on these trucks.
4wd pan has a drain plug, and a deeper sump. Holds 1.5 qts more than 2wd. Mike
Well that sure is funny, I have changed out several 2 wheel drive Trannys and they have all been the same. Care to let us know what years these are you are talking about? Maybe its a year specific thing.
