I have seached 400 post's on a search with no luck.
About 2 weeks ago I found my self having to put more and more pressur on the clutch pedal to enable starting, what I found upon inspection is that there is a switch on a lever over by the accelorator that appears to be the only electrical connection that could enable starting. The arm bushing (plastic) is worn and there are 4 wires comming out of the connector.
Question: Which wires need to be jumpered so I do not have to worry about clutch position? I will first jumper the plug to test then cut solder and heat shrink it once confirmed. I have always hated this "safety feature" anyway. I am capable of either placing in neutral or depressing clutch to start. I have had a need in the past to start other vehicles in gear due to bad clutches.
Thanks in advance.
92 1/2 F-260
Thanks in advance.
92 1/2 F-260
