Over in the Other forum, the post "Ford are you listening" from Tflips returns a page not found error. If this was pulled because it was something outragous that Ford shouldn't see, then that is fine with me. However, I was curious if this was intentional, or just a technical problem. An explaination would be appropriate. Thanks. - Mel.
Mel and Suzi's 83' F-250HD 4X4 "The Moose Truck" - Hypermax Turbo, GV overdrive, Banks Power pack, Dual Stacks, 35" tires. Winner, Best Equipped catagory, 1st annual FDR, VA. Photo Page 20 near the bottom.
I don't know why it won't come up in the Other forum. Diesel Jay moved it from the '99-up General Questions forum, and that thread is locked but still comes up to read, so you can see what it was about there.
Thanks for the explaination. I'll check it out where it was moved from. - Mel.
Howdy!
It's fixed, sort of.
The thread is still locked in the original forum, but I moved it again and you'll see that there are two threads in the Other Forum with the same topic. One is the "dead" one, which I can't delete, the other on works.
Best Regards,
Jay
