Typically, a programming error turns a 6.7L PCM into a brick. But, this could be as simple as you need to perform the PATS Parameter Reset if the engine simply will not crank. Does the engine crank and not start or do you just get nothing? Were you updating an aftermarket tune or reprogramming from stock? Also, you might want to contact the vendor where you got your tune as that might get you better help.
