Trying to sort out I get code P1211 under load. Dead headed the HPOP and got over 3000psi so I have ruled that out, also has a new IPR fitted. Next I removed the oil line from the RHS head and cranked. Truck would start when doing this test with hot oil, however when I retested the following day on a cold engine the truck would wind over and blow white smoke but wouldn't start. Same scenario on the LHS head. I reconnected the oil lines after each test and the truck would fire up straight away with minimal effort (both hot and cold) So I am suspecting that I have some worn poppet valves maybe? Any insight would be greatly appreciated
