The truck feels like im pulling 10k# behind me. It idles fine, no codes, but simply has little low end power. I have an AE and all tests pass. I'd appreciate any recommendations you may have on tests to try. I can post graps, etc.
Questions to follow:
I just replaced the fuel pump. Would low fuel pressure cause this issue?
I filled the Hpop. Would air in the HPOP cause this issue?
I've tested HPOP and ICP with my AE. They all appear within spec but idle shows ICP at 480 range. Is that too low?
I checked the front brakes for dragging. they appear fine. The rears spin significantly less, but do not appear to have any issues with calipers. Heat range of the calipers are close to their opposite side (used temp gun)
