its been too long since i had worked on diesels i am doing an engine swap took out the 8-v92tt and installing a 400 cummins in its place, forgot how to dial in the bell housing ,engine and tranny are out of the frame, so any help, in dialing in the bell housing would be great,
If its the pot type bell housing, then what your going to want to do is bolt a special dial indicator tool on the crank shaft and have some one turn the engine for you and you adjust the bell housing till its an even reading all the way around. Your going to need to find the specs out of a cummins service manual, as it will also have the procedure written more specifically than what I just told you & have the part number for the dial indicator tool. Hope this helps.
thanks jeff yeah i have the tools i used to work on these alot but i sat down the other day to do this one and totally blanked, so frustrating pain pills i took for my broken neck has my brain all messed up.
