I have 93 f350 7.3 idi. I got everything running only to find out I have a leak coming from the back of the motor on the passenger side. It’s leaking from around under the turbo by the looks of it. It’s dripping out over the starter. Any ideas?
I just realized it’s either diesel or coolant. I put some coolant in there a couple days ago and it’s almost gone. Also, could it be the fuel rail?
There isn't a fuel rail. The lines you see running between the injectors are return lines. They tie together at the rear of the engine and run to the tank selection valve, then they run up the left side to the injector pump. It might be a good idea to see what is actually leaking, and/or also where your coolant is going
