I was under the impression that the F250 and 350 had the same rear axle and if you added the camper package to a F250 you would have a F350. Looking at the Ford info I see that you can get a "F250 Trailer Tow- High Capacity (535)". This includes upgraded axle, max front springs and increases GCW from 23,500 lbs to 25,700 lbs. Also includes 20" wheels
The camper package makes no mention of an upgraded axle only heavier front and rear springs.
So it looks like the F250 High Capacity Trailer Tow package would make a F250 equal to a F350????
The problem for me is height. If I am forced to take 20's with a F250 and the high capacity trailer tow package then a F350 with 18's should give me the same capacity but be shorter in height (since I understand that in '16 they put 4" blocks in both the F250 and F350)
