With the size of your lines I'm sure you keep the pressure at WOT. So you run from the tank to the fuel filter to the pump to the back of the head to the front of the head to the regulater back to the tank? From your pics it looks like you have two fuel pumps?
I have a 5/8" pickup, 5/8" line into 1 pre filter, two 3/8" lines into 2 Ele pumps, then into another filter, then two 3/8" lines to the back of each head, then the 3/8" from the front of each head to the Regulator, then 1/2" line from the Regulator to the tank. I knew "in my never ending quest for HP", that I'll be going bigger then the 250cc injectors one day and I never wanted lack of fuel to be an issue.
JIM
