I just got a '97 F250HD with a ZF 5 speed and I am trying to figure out which gears I have. I've looked all over this site but haven't found much. Is there something somewhere on the truck that tells me? At 70mph it runs at about 2100-2200 rpms. Thanks.
It is stamped on housing or a metal tag. Clean it with wire brush and have a good light to see it.
Look at tag on driver's door, last line has 'axle', underneath is the code.I don't know how to post links , but here is address for Ford axle codes :
http://www.drivetrain.com/Fordtrkratio_posidata.html
I know axle code links appear time to time on the '99 and up board, but I don't have that info.
Yes, like Jim said , the tag on one of the bolts on the housing, to decipher the code on the tag, (again forgive me , I canot post links) go to Carpentractors page, here's the long way:
http://andersonimprovements.com/hobbies/truck/differentialid.html
Go to forums page, go to top of page and choose from the menu bar 'faqs',On next page, click on '94-97 Power Stroke FAQ',on next page,go down list and click on 'Links', Of member web sites, choose 'Carpentractor', on his page choose 'Identify your differential'.
It breaks the groups of numbers on the tag down for you, also gives a look at the Dana bolt pattern, just in case you have one .
I might mention , on my tag , the first 1 or 2 digits is covered up by the dam bolt.
I have a F350 dually stroke with a '45' axle code on the door , so my axle is a non limited slip Sterling (Ford) , ratio 4.10. I have chalk marked the drive shaft and spun the jacked-up wheels and verified 4.1 shaft revs. per one wheel rev.By the way, if both wheels spin when you turn one wheel, I (think) that means you have limited slip, but someone more knowlegeable needs to confirm that.
Someone can correct me , but I think if your axle code on the door begins with a letter, then you have limited slip, but if it begins with a number , then you have non-limited slip.
Of course, if your differential has been changed out, the door code may not help you.
Tom , '96 pSD cc dually, 158k.
Sounds like 3:55's to me too. If you have 4:10's and big tires you could put up those numbers too, but if you have stock or close size rims you have 3:55s, look at the tags to tell if its LS or not.
Ok thanks for the help. My code is 39 so I've got 3.55s. So I guess I shouldn't pull anything over 9800lbs. according to the manual.
