Ok, just got back from a 3300 mile trip to Black Hills and front range of Rocky Mountains towing my very large 5th wheel (10k plus). I have an early 2000 model truck with the OTA cooler only. As you can see in my sig, I added the largest Hayden cooler I could find up front. It is around 12" by 12" and is mounted up front, high on the condenser.
Only had two or three instances of over 220 degree temps. Most of the time, regardless of ambient, temps were 180 or below. First high temp was when running into the Hills from the south at around 25mph on winding road, ambient around 70 degrees. Needle hit 230 after around 30 min so I stopped to let it cool. Pulling the Raton Pass on I25, temps when into the 210-220 range but did not hit 230 with ambient around 80, at 45-50mph. One other time on the I25 south run in New Mexico, hit 210-220 range at around 80 ambient at 65 mph.
So, the 230 number bothers me. Seems that when I am pulling hard on a slow run, the temps will not stablilze. Not sure how far it would go and whether enough cooling could be established to overcome the extreme amount of TC heat being generated. Pulling hard with adequate airflow, temps are hotter but stable.
Do I have enough cooling?
Side Note - my radiator has the OTW cooler, that is not connected. I bought the truck used, so I don't know why it is there. Truck was manufactured without the OTW (I checked manuf. Date), so the radiator must have been replaced at one time. I purchased the tubes to hook it up but decided not to, worried that maybe they disconnected it due to a tranny failure and only replaced the OTA cooler. I could still hook that up after a good flush. I an running the inline filter that should catch any gunk.
So, hook up the OTW?
Or, I could change out the OTA for the V10.
Or, I could change out the hayden for a Tru-cool Max in front of the condenser,
Or, I could mount a cooler with thermostatic switched fan somewhere under the truck,
Or I could just leave it as is...
What should I do?
What should I do?
