would like to know its the same as the old 6.9s or a different kind of vacuum resevoir (canister). What about the vacuum pump? Trying to fix these worthless brakes.
There is a Vaccumme canister Under the Insulation on the A/C Unit. You will see a Small Hose running to it just above the rear of the Passenger side valve cover. The Vac Pump is on the Drivers side front of the engine just below the A/C compressor.
