1 - 9 of 9 Posts
Do the F350 and E350 share the same rear shakles? I'm going to lower mine 2 inches. The company I got the i beams from have shackles for F350 only.
No. The F350 uses the Sterling and the E350 uses the Dana 60.
Sorry.
The question was shackles, not axles...
The springs are the same width. If there is a difference in the shackles, it would probably be in length.
You'll need to look under the van and see if there is even room under the body for a longer shackle.
I know the rear shackle is the same as i have one off a 92 van on my 92 truck,both 350 series.
Thanks for your reply. I finally got a mail from the webshop and the shakles are the same on F350 and E350 as mentioned /ubbthreads/images/graemlins/smile.gif If there aint room, I'll make room. This Van will be droped 2 inches /ubbthreads/images/graemlins/smile.gif
In front also?
Yes, 2 inch with drop i-beams in front and shakles for the rear drop /ubbthreads/images/graemlins/smile.gif pm me and I will give you the link /ubbthreads/images/graemlins/smile.gif
/ubbthreads/images/graemlins/smokin.gif
They are the same, OBS style F250 and 350 series that is. I think the Super Duties are different.
The only problem is you are only gonna get about a 1" drop by installing the rear 2" drop shackles. You need to move the front spring perches 2" as well to get a true 2" drop at the fenderwells.
1 - 9 of 9 Posts
