Pulled with my new 6.0 today,has to be something wrong with this thing,was pulling 15000lbs would only run about 60mph to the floor?There is no engine light on or anything,temps are good,hope this isnt normal for 2006,this thing is doggy even empty.Question will ford look at it under warranty for this reason?Is there anything I could check?Its automatic.thanks
Well first off 15,000 is a lot of weight for a 6.0 /ubbthreads/images/graemlins/vomit.gif When I had mine I pull my JD 4995 around it was right at 22,000lbs and it would do just about 55 to the floor. Get a chip if you want to pull that kind of weight with a 6.0 /ubbthreads/images/graemlins/vomit.gif. OR sell it like I did /ubbthreads/images/graemlins/biggrin.gif
