99' F250 Super Duty. Dome light on truck will turn on manually but won't turn on when I open the door. Seems that there is 3 settings on the light above the center console. If I understand the settings there should be On (left side), Off (right side) and On when door opens (middle). Light works fine when I slide the button to ON, turns off when I slide it to off but won't come on when in the middle setting when opening door. Also, when I close the door the outside rear light above the bed stays on for a minute or so and when it shuts off it will still have a slight dim and kick the inside dome light on, also a slight dim not full light. This is when the setting is again in the middle position. Seems awfully strange.... So currently I have it in the off position so don't keep something on.
I hopes it a simple fix like a bad fuse, bad bulb or something like that. Also read that maybe the switch on the door is not operating correctly. Spray a little penetrating oil on the latch and close/open the door several times to loosen something up???
Hoping that somebody here on the forum had this same problem and could offer their fix solution. I plan on starting on the simple solutions (fuse and bulb) and work from there. Hope its not something electrical that I have to chase... Thanks - Scott
