Im new here so bear with me. The door ajar light stays on. Can't lock doors. A Dallas ford dealer told me they sprayed with WD40. They then told me they could not fix. Got any ideas.
My previous 01 Lariat F350 had the problem where the dome lights would stay on and the door ajar light would stay on, but it did allow me to lock the doors using the keyless entry or the inside door lock switch, and the lights would go out after about 30 minutes. The sensors, supposedly in the inner door latches, "hang up" and require a shot of WD40 to free them up. I sprayed each inner latch with a healthy dose of WD40, and it took about 2 days (and multiple open/close of each door) but it did correct the problem. Yours sounds like a different problem if you cant lock the doors.
Discussion Starter #6
Thank you got door ajar light fixed. Service manager handed me a funny piece of plastic. Said it had broken off door onto the striker.
