My 02 F350 CC, LB Lariat, 6 speed has a weird front drivers side door lock problem. With the key fob everything works normally. When I just use the key to manually open the doors it will only unlock the driver's door and the dome lights do not come on. The door ajar light works as it's supposed to. If I turn ignition switch to on or accessory everything works fine about once in five tries. Many times the power door locks do not work even with key on. Radio stays on ignition off door open, again about once in five tries.
I have replaced the door latch assembly, power door lock actuator and the door ajar switch. Still cannot open all four doors from drivers side key insert?
Bill
