Have a 2002 F350 PSD Crew Cab. The piece of black rubber strip that runs vertical along the edge of the back of one of the rear doors fell off. It just presses in from what I can tell. It's about 18" long, quarter inch thick or so.
Anyone ever have to order this and have have a part#? /ubbthreads/images/graemlins/shrug.gif
Are you talking about the rubber thats at the bottom of the rear CC door glass. If so, is there any rust were the rubber was? Mine has rust under there from the rubber metal spin rubbing the paint off! If the dealer replaces mine, I will give you my old one /ubbthreads/images/graemlins/phoney.gif Do you need drivers side or passenger side?
Louie
No, not the one at the bottom of the glass. If you open the door, look at the open door now at the end by the door handle side. Mine has a vertical strip of rubber which is pressed on over the edge of the door.
Thanks anyways!
Ok, found out what these are. They are door edge guards, they are aftermarket pieces of rubber that press on over the edge and seal with built in glue. I found some at Advance Auto parts called Trime Brite. They say on the box they are 3/8" but they only measure 5/16". The ones on the truck now are 3/8"....
