This is a somewhat intermittent problem. When using the remote to lock the doors on my 2003 F350 Crew Cab King Ranch, I sometimes get the double beep of the horn. I can predict it is going to happen by watching the lights on the running boards: if the first click of the remote lock button turns them off, just a single beep indicating all is well. If the running board light does not go off on the first click of the remote, the double beep of the horn occurs. I have found that if I repeatedly lock and unlock the doors with the remote, eventually the system arms correctly.
I am suspecting it might be the door latch switch that others have problems with, but I do not get the door ajar light on the cluster.
Has anyone seen this behavior? Suggestions?
Mine does it every time I use an aftermarket remote lock/starter/alarm. It does lock the doors and after a few minutes the alarm mode works. A little weird but it works so I don't mess with it.
My 02 also does it all the time. I thouht it was just letting me know it was locked.
