How do you tell if they have lost thier seal?
· Super Moderator
You'll start to get moisture condensing in between the panes.
Jim
Just like bugman said you will get moister in them they will start to fog up.
What about moisture building on the inside of the window?
· Super Moderator
If they lost their seal the moisture will be between the panes. If you are asking about the side that is inside the house it just means that you have a moist environment in your home. A window will always be cooler no matter how many panes it has unless it is heated someway.
Jim
