1 - 15 of 15 Posts
I would call on this but i know they are moving so i thought i would ask here. When do all of you turn it from stock to which ever setting you usual run on.In the diretions Jody says to change it after the engine is warmed up,but i got to thinking about the PCM burns he does and thoses are on when the the truck starts.So i got to thinking(which i do alot of) that maybe i could change it as soon as i started it up. Just wanted some opinions on this.
ive only had mine about 2 weeks and mine stays in 80 econ all the time. start it up in that and just let it warm up good.
SdPj
The reason for those is to just try to keep you from stressing the engine too much when it's still cold. You don't wanna turn it on a high settings and throw the pedal to the floor on an engine that's still cold. Just keep things below around 2,000 rpms without heavy throttle until the engine warms up and I'm sure you'll be fine. All those people with PCM burns or SCT tuners would be up a creek if it was really a big deal.
· Banned
Over a year and a half with mine and I almost always start driving right away in 80 econo. I never had a stock setting until recently when Jody reburned my chip, but I don't use it anyway. Only on the very coldest days I would put the chip on the 40 tow setting. The reason is just because the injectors were super noisy in sub-zero temps, and usually there's snow on the ground at the same time, which makes driving a bit squirrelly with extra power.
[/ QUOTE ]hey pocket when the injectors get noisey is that bad. when its on stock it sounds normal when i put it on 80 eco its louder im guessing the injectors. my dad heard that hes and oldtimer muscle car guy and he said man ur injectors sound like crap they are gonna go for sure. is he right is this dp gonna cut down on the life of my engine. i dont run it that hard.
· Banned
Nah mine are noisy in sub-zero temps no matter what tune it's in. Every other PSD up here that I've heard sounds just like mine when the weather is like that. It's only slightly less of a knock in the 40 tow setting compared to the 80 econo. Mostly I switch it over because of traction issues, not noise. But I guess part of me also changes the tune because I'm paranoid.
I never noticed any problems with the injectors. They all contribute nicely according to AE with almost 100K on the ticker.
Man... your starting to panic... If you cant risk a motor then dont chip it! Not trying to be a smart arse but
[/ QUOTE ]no i just got nervous im over it now. i had a blast yesterday i showed someone the 4x4 launch
Discussion Starter · #10 ·
Wish i could do a 4x4 launch,i can do a 4 wheel launch but i still spin them
[/ QUOTE ]how?
Dually
hahahahaha 4x4 launches are the STUFF!
Discussion Starter · #14 ·
A dually launch
1 - 15 of 15 Posts
