I've been chasing the old P132B issue on my 03/04 for a while... I've done all the checks for the exhaust leaking; MAF and MAP issues (found a hole in the MAP hose along the way) and also tried to do the re-learn of the VGT following the instructions. But one thing was the P132B also calls an "Intake leak" as a possible issue... Does this mean before or after the Turbo? I found that the o-ring on the air intake tube that leads from the valve cover to the inlet hose has rotted off... I would "guess" (as that is all I am doing at this point chasing) that this might be enough to suck additional air after the MAF sensor and throw off the reading/calculation during a re-learn?
Thanks,
Curt
Thanks,
Curt
