I'll be driving across country from North Carolina to California in the next 2 weeks and I was wondering what are some things I should check before leaving on the trip across the beautiful usa. There's nothing wrong that I know of she runs good, sounds good, the idle isn't variating. But I figured there's some preventative maintenance that I could conduct. I have a 2003 ford f250 7.3 with a 6' lift (rough country). Look forward to the communities advice, thanks.
Double check to make sure you really want to go to Kalifornia. If you do, then check your belt,. I'd actually get a new one and put your old one behind the seat as a spare. While it's off, check every pulley for play. Check all radiator hoses. If you don't have the top hose that goes around the belt, swap it. Clean air filter. Fresh oil. Check the axle lube. Do your wheel bearing maintenance and check your brakes. Spare tire inflated? Got your jack and tools? Still sure you want to go to the ROK? Got all your shots? I'd carry a gallon of antifreeze and oil, and a couple quarts of ATF. Wipers ok? All fluids topped off?
have some spare CPS, some oil, coolant, Lot of additives if you use in your fuel tank. I just did British Colombia (Canada) to Quebec (canada) last September and will be doing the other way to british Colombian next week (will probably be going trough USA). what I do before leaving is oil change with new filter and new fuel filter. I check all other oil level (trans, diff, transfer case and coolant). in the back I have bunch of tools in my tools box, jack, jack stand, some engine and trans oil and bunch of piece of wood.
Hey guys sorry for the late reply, work has me bouncing off the walls, so, yes I have to go to california, I don't have a choice in the matter. It's where I'll be staitioned. I saw alot of advice from all of you and I want to thank you guys, there alot of things that were mentioned that I don't have a clue about. And it's pretty much moat of it, I can Google it and figure it out and start looking it all up and get familiar with her. It came with straight pipes so that's one thing I know I'll have to change before I leave or when I get there. The owner just cut it out and welded a pipe on there :\. Anywho I will start going through all the suggestions one by one and conduct all the possible preventive maintenance. This will certainly be a journey
A broken serpentine belt will leave you stranded on the side of the road so its good to be pro-active and change it before that happens :winking: there are many DIY videos on YouTube. Here is one: http://youtu.be/u9uobrGJVtg
Here is the best deal on a new Serpentine belt. (This is for engines with only one alternator.)
Most of our 7.3s came from the factory with a top radiator hose that is routed through the serpentine belt and it needs to be removed to change the belt. While it is off this is a perfect time to install a new top hose that routes outside of the belt. It was used on ambulances with two alternators and it doesn't have to be removed every time you change your belt. It costs about $20. Here is a photo of the "good" style top hose. Maybe the previous owner already swapped yours?
RT has suggested that you inspect the pulleys when you have the belt off (maybe someone can give you pointers on what to look for if you only want to inspect them). You want to inspect them and roll them by hand while they are not under tension of the belt. There are two seperate parts you need to inspect. The first is the idler pulley and it is a single pulley. The second is the belt tensioner and it is one part with 2 pulleys.
If you decide to replace them then the cheapest place to buy genuine Ford parts is Tousley AutoNation Ford. They are a site sponsor.
One question you will need to think about is if you want to always replace parts with Ford OEM or if you will try and save money buying after-market parts. This is a personal choice but many guys here like to stick with Ford OEM. Here is the online parts catalog for Tousley Ford. They charge a flat 10% above cost and even with shipping they are always cheaper than your local Dealership.
That actually looks relatively easy changing all that out, the pulleys look like they may be more difficult if one is found to be playful thanks for posting the vid
You can always say it was too damn cold to slide under and look!
On your hose picture - Yours is a perfect example of this. Diesels vibrate. Anytime a hose is next to something hard, it will wear through. The driver's side CAC hose is one example. The pressure hose out of the power steering pump is one. And this hose is one. See where that cool metal recess in the alternator mount hugs the hose? You can make out its impression on your upper hose already. Wrap that portion of the hose with a few layers of bicycle inner tube and zip tie that puppy into the recess to keep it from bouncing into the fan belt.
On a side note - your hose looks like its sucked in pretty good. Why are you running a vacuum on your cooling system?
Here's an update I'm in Oklahoma so far, had to add coolant in alabama, made it to Oklahoma and woke up today she didn't wanna start, the batts were dead. Made it here without any worry. Got a jump and now the abs light is on. Check the lines to the tires and front driver side has 1 line that goes into the rotor is melted away. That's what made the abs light pop. Though I'd revive the thread and let you guys know what's going on.
PM 444-4D. He's an Okie and if he isn't close, he'll know someone that can help. If your rotor got hot enough to melt the ABS sensor wire, I suspect you've got a sticking brake caliper over there. Not an enjoyable roadside maintenance item, but it needs to be addressed.
Hey guys just got into cali today, I'm going to get the batts tested but, they've good thus far, it must've been the cold, in NC it wasn't that cold. It was, I think 40? It was in the goldsby area. The wire was pressed up against the rotor so after all the travel it melted. But I haven't had any issues other than that. Not sure when the batteries were replaced, the guy I bought it off didn't know :\. Other than that I made it here safe, other than putting some coolant in there it was runnin strong.
Look up rest stops, or motels in advance. Download an app that lets you know where gas stops are, and prices. GasBuddy is one I have used.
Get a spare tire, in case of a blowout, and a container of fix-a-flat. If you do not have an air compressor, now is a good time to buy one.
