There have been many folks here that have replaced the DMFW (which you have correctly called). Most folks choose to replace the flywheel and clutch with a single mass flywheel/clutch assembly since the DMFWs were a problem area. The job is fairly straightforward, just use a tranny jack to lower and move the tranny back. I put in a Southbend Con-O setup and love it, while many others have gone with a Luk SMFW kit. If you replace it, replace the clutch release lever while you're in there. Cheers!
