1 - 14 of 14 Posts
I believe the UG is a shortened RUG- Regular Unleaded Gasoline. Used as a thinning agent
correct rug is regular unleaded gas.. UG was a typo
Do a search of this forum. There is a WMO how to thread that I wrote awhile back that many off us have repeatedly asked to be made a sticky. You will find just about everything you need to know in that thread.
Well thanks for cluing me in!!!! I am looking at a 99NPR that has sat for 2 years with only 130,000 miles on it. I tinkered with it and got it to spin over but I got scared to keep cranking since the batteries on it were off my e350 parked along side it. LOL. I think the cables need cleaned at the starter since it clicked alot before it turned over. I ask, is there any serious issues other than obvious fliud/filter changes needed if I get this thing running? And, is it possible to power something as complex as this Isuzu with waste oil????
UG is a caveman word, used when male bonding rituals are performed around a barbeque!
"Ug! Meat! Fire! Beer! Ug!"
On this forum it could also be mis-interpreted as Unleaded Gasoline!
:thumbsup:Much better explanation than mine
Isuzu NPR's are powered by a 4BD1 or 4BD1T [ if it's turbo ] there are variants eg: 4BD2T which had electronic timing control but still mechanical IP.
early versions were IDI then they switched to DI but intercooler models went back to IDI.
They're good for 1/2million miles [ then re-sleeve again ] have about 135hp [intercooled] and 395ft/lbs.
They are basically a Jap Cummins [4BT1 vs 4BD1] and respond to all the same mods as a Cummins.[ both are 3.9Liter ]
Put a bigger "snail" on it , and "turn up the wick" and it'll get a reliable 200-250hp and 530+ ft/lbs.
Thats enough grunt to pull the neighbours house off the foundations!
The Aussie Army swapped these engines into Land Rovers.
Discussion Starter · #10 ·
Awesome. Thanks. I know it is a turbo motor, but I thought there were 5.2l versions. Am I wrong? At any rate I don't know if I'll ever see 500,000 miles since I drive about 10k a year. But that is good to know. SInce it did spin over fine, is there any reason to think if I had just kept cranking it would have started? Should I put some diesel additive in it? Thanks again.
The 6 cyl version is the 6BD1T [ 6BG1T is industrial only ] , basically the same engine with 2 extra cylinders , they are 5.8 liter . 195 hp and about 560 ft/lbs.
The 5.2 versions [actually 5.4] were a 6BB1, they had shorter stroke crank and are late 70's early 80's engines
Again they're all Jap Cummins [ 4BD1 and 6BD1 vs 4BT1 and 6BT1 for the Cummins ]
The 6 cylinders are a large engine weighing almost 1000lbs but have enough torque to pull a building inside out.
A swap would be similar to a Cummins except the exhaust is on the other side [ originally for RHD in Japan ] , they also have a SAE bellhousing pattern, so a NV transmission might fit.
Most are 24v so if it doesn't start, check the solenoid on the pump that switches on a fuel lever [ you can also convert these to cable, if you have a 4x4 that likes to go swimming ]
To "kick it in the Guts" [kiwi slang] give it a sniff of "white spirits" which is safer to use with glowplugs.
Only 10k / year, the Isuzu should see you through to 2061
Discussion Starter · #12 ·
Appreciate the input. Really. What are these "spirits" of which you speak? Corn Liquor???? I aint got no shine in these here parts. Ha.
Haha! I haven't tasted 'shine since I was a 13year old kid, when my dad gave me a taste after a stockcar meeting. [ even in NZ this sort of activity went with stockcar racers ]
The "white spirits" needed for sniffing the diesel engine is a purified mineral turpentine. [ the best is used by tire shops to soften rubber for vulcanising ] just tip a "bottle cap" full down the intake hose
White spirits is safer than ether or gasoline!
It gets really exciting when ether hits the glow-plugs while the intake valve is still open.
Discussion Starter · #14 ·
Cool beans! Yea, 'white lightnin' shouldn't even have much taste if it's the good stuff. At least that's what they tell me. I'll try the mineral spirits if I can find it. I might not need it either. So who knows. BTW. I did thin some old motor oil this morning with a lil 87 unleaded. I eyeballed it between 10-15% total volume. I strained it through a paint strainer and dumped it in the ol 7.3idi. Not even a change. I got a guy down the street with a garage who has to pay for waste oil pick up. I've spoken to him and he's cool giving me some. Just tell em you want it for a fuel oil heater for your house. Nobody's gonna ask twice........
1 - 14 of 14 Posts
