1 - 17 of 17 Posts
Drove down to swamps diesel for some live dyno tuning. Had no problems with the dp chip, just wanted to try something different.
429/773 in overdrive
425/682 in drive
Had a blast!!!!!!!
Congratulations !
Definitely happy!! Even with the water, I am probably leaving 30-40 horse on the table without an intercooler. I will post the graphs up soon.
Plenty of fuel left to make some much better numbers when the gt 47 gets on!:thumbsup:
what a blast it ought to be to drive. would love to tow my 5ver with that. enjoy the ride and the tinkerin. richard
425/682 in drive
Had a blast!!!!!!!
wow id like to see some motor pics how are you getting thoes numbers ?
Discussion Starter · #10 ·
It doesn't look like much, but it sure runs good.
Not sure what you are asking... The combo is in my sig abd I used a Dynojet 248c chassis dyno.
Holly Smokes!
That sounds incredible. I love my 7.3, I never seen an engine pulled out like that, have any more pics, like an album in webshots or something? My van is quick, but yours sounds like a rocketship. I blow cars all the time at stoplights, they get so mad they try to beat me at the end of the race when I back off. The sonnax & trim springs give it a nice shift.
Do the 2009 Vans have the intercooler?
Discussion Starter · #12 ·
Holly Smokes!
Few more of the engine swap.
Old one out and new one in.
Are the 09's still the 6.0? The 04 up 6.0s were intercooled.
RPM,
Can you tell me more about those hybrid injectors. I was looking to get some stage 2, but if the mod injectors work well and are priced better Im in. I want to get upgraded turbo as well. Would like to put 400hp down to tires. What mods do you recommend to get there.
Paul
Discussion Starter · #14 ·
RPM,
Paul
Copied from another site about injectors....
Larger nozzles- By installing larger nozzles you are makeing the nozzles less restrictive so that more fuel will flow out of them with everything else being the same. Stock injectors with stock programming and larger nozzles will get more fuel out and make more power. Stock injectors only modified to have more fuel capacity with stock nozzles and stock programing will run exactly like stock injectors. In this case the only way to get more fuel out is with a chip to extend the open time of the injector and/or increase the Injection Control Pressure (ICP) to push more fuel out the nozzle. On the same note if you say make a hybrid (installing a larger 7mm plunger and barrel out of a DT466/I530E injector) and leaving the intensifier piston the same will effectively reduce your injection pressure. This less injection pressure will make less pressure at the nozzle and will actually flow less fuel with a stock nozzle than a bone stock injector. So to get the fuel out without a chip you would need larger nozzles.
There is also a point where the stock nozzle just wont flow enough fuel to get the desired amount out in a realisitic time frame. That's why high capacity injectors require larger nozzles to use that capacity.
Codes- All powerstroke and T444Es come with A code injectors. A code injectors have a 6.0mm plunger and a 16mm intensifier piston. What this does is multiply the ICP so that injection pressure is adiquate but not having to have huge amounts of ICP like say in the 20,000 psi range. This difference give you approximately a 7:1 difference and therefore increases your injection pressure 7 psi for every 1 psi of ICP.
All DT466s and I530E injectors are B codes. Of those some DT466s and all I530Es have a 7.1mm plunger, hense more fuel per mm of stroke, with a 17.5mm intensifier piston. This gives you approximately a 6:1 ratio. So no it will not have quite as high of ICP as as the A codes but it's not as bad as it could be. However due to the larger intensifier piston they reqire much more high pressure oil to make the piston stroke the same distance. This is why you need a high pressure oil system with a higher capacity.
Hybrid injectors are taking the 7.1mm plunger and barrel out of a BD code I530E injector and installing it into an A code injector with a 16mm intensifier piston. As you could imagine the down fall is that the injection ratio is dropped to approximatly 5:1 further decreasing injection pressure. However with the smaller intensifier piston it requires no more oil than an equivilant A code yet it flows the same amount of fuel as a B code. The result is much more fuel capacity without the need for more high pressure oil volume.
A codes and B codes can be further broken down as well.
A and AA injectors came in the '94-'97 non-california trucks. They are all 90cc injectors and are single shots.
AB injectors came in the '97 cali, and all early '99 trucks. They are split shot injectors meaning they fire a small pilot shot before the main shot. These injectors flow 130-135cc of fuel.
AC injectors are found in the high torque version of the T444E and do not come in any Powerstrokes. They have the same internals as the AB injectors with the exception of the single shot plunger and barrel. However due to them being single shot injectors they flow 160cc. This is due to the way the split shots work. They have a small passage that opens, much like a port in a two stroke engine, that are uncovered that bypass the injection pressure out the side of the barrel instead of out the end through the nozzle. Because of this pause a portion of the travel of the plunger does nothing for injecting fuel so a split shot injects less fuel for the same amount of travel as a single shot.
AD injectors are also split shot but flow 135-140cc of fuel due to a slightly longer plunger stroke. These are found in all late '99-'03 Powerstrokes and T444Es.
AE and AF injectors are essentially the same as AD injectors but were called a long lead injector that was used as an attempt to cure a "cackle" issue many people complained about.
BA, BB, and BC injectors are essentiall all the same and are the same as AC injectors but are found in some DT466s.
BD injectors are the only B codes with the larger 7.1mm plunger and barrel that are single shot injectors. These are the injectors people are usually talking about when they are talking about putting I530E injectors in their Powerstrokes.
BE injectors are essentially the same as the AD injectors but found in some '97-'99 DT466s.
EF, BG, BI, BJ, BN and BP injectors all have basicly the same capacity and are split shots. However the nozzles vary on them depending on application. They can be found in many DT466s and I530Es.
The setup I have is very popular (in the trucks anyways). We are obviously at a big disadvantage without an intercooler, but water injection makes up for some of that. With the hybrids, you can do without big oil, and still make good numbers.
Check out DIY-Injectors.com. That is where my hybrids came from.
info
425/682 in drive
Had a blast!!!!!!!
DP Tunes, forged rods, exhaust ported heads, comp 910's, h-11's, stealth twin pumps, 230cc hybrids,
sorry maybe knowing your acronyms for >DP Tunes,, exhaust , comp 910's, h-11's, stealth twin pumps, 230cc hybrids,
and the others that you mentioned might help , also let me introduce my self , been a member sense 01 very much into the vans , looks like your getting somewere with the HP numbers , concgadulations !
do you still have the air heater device in the intake after turbo?
what did you do with your valve cover breather tube that was connected to your intake ? tube leading to turbo
did you disgard the exaust valve cold weather device in exaust exit side ?:thumbsup:
Discussion Starter · #16 ·
OK!! Sorry about the confusion. I will be more clear...:thumbsup::icon7:
DP tunes-www.dp-tuner.com One of the best tuners for the 7.3. There are others, and the dyno runs were with Swamp's Diesel Performance tunes.
Exhaust ported heads-I paid someone good money to go at the heads with a grinder!!
I wish i had a stocker port to compare it to, but I don't.
Comp 910's are valve springs. summitracing.com
These keep the valves from floating with a lot of boost.
H-11's are head studs to keep the head gaskets from blowing. I am using stock gaskets with these studs.
The stealth twin pumps was a diy kit from www.beansdieselperfomance.com. It is a form of "big oil". Don't think it is available anymore. It allows 2 factory high pressure oil pumps to be mated together to provide more injection control pressure than one pump can.
The hybrid injectors were built by Jim Rose from DIY-Injectors.com.
Hope this helps, I am by no means an expert on this subject. I just read what was working for people, and put this thing together.
Oh, the air intake heater (aih) I deleted a while back. The breather (search ccv mod) is exiting at the rear of the van.
Hope this helps!!!!
thanks
Comp 910's are valve springs. Summit Racing - High Performance Car and Truck Parts | 800-230-3030
Hope this helps!!!!
thanks alot ! i have 160,000 on mine 4x4 and i was into hopping it up for a couple years , now you made me get back into it thanks keep posting ! il start a new thread on my GM (general maintinence ) fuel inj change out , by the way i had 38 lbs boost until i started having fuel tank problems , and the smoke would flow when hammered it ran 16.1 at capital raceway MD this truck weighs 7450 lbs on scale at truck stop so you have a big adavatage i never had it on dyno i wish i did now
now i have no power , no smoke , and great fuel mileage cause non is getting in motor lol
1 - 17 of 17 Posts
