Does this mean the carrier for the Dana 70 will drop into the housing? I have the FF Dana60 on my '01 and the housing is stamped as a 70 model.
Colin
From what I understand, yes. I did not do that because of the extra cost, and mine was doing just fine, even at 175,000 miles, and lots of heavy towing. I used the arrowcraft adapters for my dually conversion, and I do run right up at the 7800# axle rating so it's passed the endurance test in my book.
The shop did say that the ABS/speed sensor would have to be relocated because the ABS ring is in a different location. That of course would require drilling a new threaded hole. They also said they could try welding the ABS ring to teh proper location for the current sensor, but that can involve a bit of trial and error. They didn't say it, but I suspect a new cover may be needed too.
