21 - 24 of 24 Posts
Jack it up, pull wheel, axle flange bolts, pull axle, get axle nut socket with the pilot collar that is part of it. Pull hub, replace brakes.,get new splash sheield, hardware shoes ect.Clean hub, bearings, repackes repalce inner hub seal.
1995 power stroke 4 wheel drive ,tried doing a brake torque but before tires broke loose something sheared off,trans ran perfect before this but now it don’t move in any gear, I hear a slight whining when I put in gear ,do you think I blew the transfer case , help
With the transmission in Park, does the truck hold still? That is, could a person or another vehicle push/roll the truck while it's in Park?
21 - 24 of 24 Posts
