E40D issues, maybe someone else has had this issue in here?
So, I have a bit of an odd issue with my transmission.
It seems to operate normally for a few miles, then I will only have third gear. I can manually shift it into second, but if I put it into first... I still only have second. I also don’t have fourth gear when it starts acting up. So when I take off from a stop, i need to have it in second gear, and when I get up to speed, I manually shift it into overdrive to go into third. Come to the next light, I manually shift it back down into second.
I drive it the next morning, once again it works perfectly fine for a few miles, then I lose first and fourth.
Any ideas what might be causing it? The fluid isn’t burnt, or dark.
It is a “new” rebuilt transmission, it started acting up about 1500 miles after install.
Any help is appreciated!
