Hi all, just joined to hopefully pick someone's brain. Upstate NYer (near the Mass/VT border) with a '97 F250 ECLB. I'm aware after hours of reading that there's a resident E4OD expert, hopefully he will see this.
To make a long story short, the truck has some miles...332K as of now! I bought it 6 years and 9k ago with 2nd gear barely working. I've limped it along using manual 2nd, driving with a light foot and have gotten a lot of work done frankly. It's not a toy
, daily driver is an '87 Grand Marquis and the toys are hopped-up 87/88 Cougars. Finally getting around to really troubleshooting because I've never felt like I should give up on it.
Where I am now after a bunch of Sonnax parts and some other drive-testing: I rigged up a string tied to the solenoid harness plug (don't ask me why it took me 6 years to dream this up...). I took off in manual 1st, hammered down and pulled the string. I'm aware that this condition gives me 4th and 2nd, and I found that Manual 1 and Manual 2 keep you in 2nd, moving to (D) gives you 4th. I was shocked with a solid banging 2nd shift, the likes of which this truck has never been capable of, even with the EPC wire disconnected. (Note: I have installed all 3 Sonnax 1-2 fixes just recently and a TransGo HD-2 toward this effort)
So my question is, why did this happen? I haven't been able to find a recounting of a test like this, nor a description of what's going on hydrualically with no solenoid pack power. If the band is still doing the work here then clearly the clutch is indeed done for. But if only the clutch is active...then perhaps I have an SS1 or SS2/wiring/ECM driver issue?
Cheers,
Paul
Cheers,
Paul
