Won't downshift on uphill grade under load. Changed fluid, filter, stock trans, no codes. It also is slugish when towing (uphill), but I think that's a gear ratio problem. I have 36" tall tires with a stock gear.
Have you reprogrammed the speedometer to go with those 36's? Cheers!
Does the speedo read the speed accurately (same goes for the odometer and miles)? Cheers!
· Super Moderator
The same speed sensor that runs the speedometer and odometer are also used to input the speed to the transmission controller.
Thanks everyone
I spoke to the original owner and no he didn't reprogram the computer. I'll get that done as soon as my edge programmer comes in. In the meantime, I changed the fluid in the trans, new filter and added lucas additive. Man that cleared it right up. It downs shifts and shifts much smoother now. I guess the solinoids where gummed up after all.
