Hope somebody can help. I bought a 99' F250 Super Duty 2WD with 284,000 on it. I plan on hauling a 30' tag travel trailer and I know this will get the job done as soon as I get it running a little better. Runs rough at a idle until I get the temp up past cold on the factory gauge. It does run a lot better when it warms up. Guy I bought it from said his mechanic had put a couple of aftermarket injectors in it, so I figure before pulling with it, I should do some troubleshooting. Did a buzz test and #1 sounded weak compared to the other 7. After reading on troubles with valve cover harnesses, I figured I would at least install new ones with since it had so many miles on it.
I pulled right bank cover first since that is where #1 is and I found the two injectors he told me about. Pulled the left bank and found this.
2) AB, 4) AB, 6) AB and 8) had AF. 1) AD, 3) AB (alliant brand), 5) AB and 7) AB.
Now correct me if I am wrong, but I believe # 8 is suppose to be AE, and #1 should be a AB like the rest of the Injectors. I dont know if having an off brand compared to the other 7 (Ford I assume) would make any difference. The truck is manufactured on 1/98 but it is considered 1999.
Any comments would be appreciated. This my first time wrenching on a Diesel.
