Hi guys,
I ran my tank just slightly dry a few weeks ago. I pulled in once it got lumpy, got a ride to the gas station, got some fresh fuel, filled it up with a jerry can and was on my way after 2-3 ugly sounding cycles. Luckily I didn't lose the prime in my pump.
I do rotational work in Northern Canada so I'm gone 3 weeks at a time. I have my Dad or a family member go and start my truck once every 7-10 days and let it run for 5-6 minutes. He has been having difficulty starting, usually it takes about 3-4 cycles and a bit of throttle to get it going. Batteries, GPR and starter all new within the past year or so.
So when I get home next I had a few things in mind.
Going to swap the fuel filter, drain and clean the bowl and spray in some seafoam to flush it out. I will also check the pressure on it. I know 3 injectors were replaced 10k miles ago before I bought the truck
I've also been reading about a FPR screen. I see it is in the 94-97 IDI 7.3's but would my early 99 also have one? Cleaning this seems to do great for the trucks but wondering if mine has one.
Should I also look at shimming or replacing the FPR? Truck is an early 99 with 171k miles (275k km). Not sure when/if these tend to give out.
Not home very often to visually inspect these things so planning in advance for me is critical as I need a reliable vehicle when I'm home. Recommendations/criticisms welcome :grin2:
