Hi
I need to replace my early 99-Build date 8-98-wheel bearing hub assy. These are very hard to find and very expensive. I was told I can change them to the later 99/2000 if I change the rotor that matches the later model. Is this true? Also when I asked for the rotors they are asking if it is a mono beam front axle?? What is mine and how do I know? Thanks John
Hey
I have a early 99 F350 Dually crew cab 4x4. I found a great price on the hubs on e-bay. They are for 99 after 3/22 production date 4x4 dually with abs. They dont have rotors. When I call the local auto parts guys for the rotors they ask me if it is for mono beam or twin beam from end???? What do I have?
John
· Administrator
You can use either early 99 hub/bearing and early 99 rotor OR late 99 hub/bearing and late 99 rotor. If you mix them, you'll have interference problems with the calipers.
All the 4x4 Superduties are monobeam, earlier F250's had IFS (independent front suspension) axles. The parts guy isn't paying attention.
