So I just recently did the non-E BPV pedestal conversion kit and now I am wondering what do I do with that plug that went into the solenoid sensor on the original pedestal. Do I just leave it hanging, is there a bypass pigtail set up for it or can you use resistors for it
470 ohm 1/2 watt resistors. 5 bucks
Delete plug from riffraff 40 bucks.
Cut the old plug off the other pedestal-free
Diesel-O-Rings sells the resistor for $1.00. Go to their website and look under the "SHOP SUPPLIES" tab.
Well an 8 pack from radio shack is 4 bucks lol
Connect the solenoid to the plug and leave it in the engine valley. This will prevent a code being thrown for it.
I did exactly what Justin said.^^^ Remove the sensor unit from the old pedestal. Remove any extra weight. There is a blue aluminum sleeve,etc. Next, I wrapped it with black racing repair tape and zip tied it up out of the valley. I didn't want it rolling around in there. Works fine and no codes. Best part was I cleaned up the old pedestal with brake clean and sold it on eBay for $100! Guys with pre-99's will buy them. Cheers!
