I second the question. I am also wondering because it seems to be talked about a lot here.
Probably unrelated to the EBPV deleteI did the EBPV delete on my 01 F-350 this past summer and during the warm weather it seemed to run fine. However, in colder weather, it runs terribly. I can let it idle for 10 minutes and still feel like it is lugging. After it warms up, it will run fine again. The cold weather I am referring to is less than 40 deg F but warmer than 25 deg F (it has been a mild winter). I am considering reinstalling the stock pedestal and butterfly valve this spring.
I would also say that this is another issue. I have the EBPV delete for about 3yrs and been -40*C (Canada) with no issueI did the EBPV delete on my 01 F-350 this past summer and during the warm weather it seemed to run fine. However, in colder weather, it runs terribly. I can let it idle for 10 minutes and still feel like it is lugging. After it warms up, it will run fine again. The cold weather I am referring to is less than 40 deg F but warmer than 25 deg F (it has been a mild winter). I am considering reinstalling the stock pedestal and butterfly valve this spring.
I don't understand why you would not use the superchip "high idle" when you describe issues of the truck running terrible when it is cold.The idle will eventually jump up. I have a superchip that has the high idle setting but I rarely use it. What other cause do you think would cause these symptoms?
Those were my thoughts on the EBPV also.Ya high idle would def help.
The temps he is having issues at aren't cold anyway.
The ebpv delete isn't the reason for his issue.
The guy I bought the truck from installed the superchip selector switch up under the steering column. It is very inconvenient to use. I have been meaning to move it but I haven't got around to it yet.:frown2:I don't understand why you would not use the superchip "high idle" when you describe issues of the truck running terrible when it is cold.
I am using Amsoil SAE 15W-40 Heavy-Duty Diesel and Marine Oil.Sounds like Low armature clearance on some injectors.
the valve won't help much until it warms up either.
Try running a thinner 5w-40 oil.
