Hi all,
I just installed a egr delete kit, But am just wondering dose the sound of your turbo spooling up change? There is and extra whiz in the sound of the turbo spooling. I thought it was a leak at first but after re-installing everything 3 times now I am just pissed off :icon_mad: and confused !!! Any help would be greatly appreciated. Thanks all.....
Check for holes in the up pipe on the right side, you might have developed a pin hole in the bellows if you kept the old pipe and plugged it with the replacement disc plug. New up pipe must be seated well before tightening if you used one. After 04 the pcm is affected by egr delete and must be reprogrammed for the delete.
