1 - 20 of 23 Posts
I'm thinking about doing a EGR delete on a 2006 6.0L and coolant filter. What brands are recommended? Also what are some of the known issues with the delete on a 2006 6.0. Thanks in advance.
Far as I know doing the delete you eliminate alot of problems. While your in there I would get oil cooler upgrade or oil cooler relocate kit.
Sent from my SAMSUNG-SM-G870A using Tapatalk
There is no downside to deleting on an '06. I would recommend the kit from IPR. Its a really well though out kit. Here's a link to it on their site:
https://www.iprresearch.com/IPR-GEN2-EGR-Delete-Kit-Includes-Intake-Gasket-Kit-for-all-2005-2007-Ford-Powerstroke-6.0-will-fit-F250-F350-F450.html
As far as what else to do while you are in there, I would suggest a turbo cleaning, because the turbo has to come off anyway. I would also highly recommend replacing the stock Y-pipe. Once you remove the EGR cooler as a point of support the bellows in the RH leg of the pipe will fail, and you'll have soot going everywhere and excessive turbo lag. MPD builds modified Y-pipes on an exchange basis. They eliminate the factory bellows in favor of stainless steel flex couplings that will not fail. You may have to modify the heat shield on the LH side to ensure enough clearance for a proper merge collector to turbo seal though, because the new coupling is bigger than the factory connection and typically interferes with that heat shield making a tight merge collector to turbo seal impossible. A few whacks with a hammer solves it pretty simply. Also, change the hot side CAC boots; they typically last 5-6 years before they start to crack and fail causing boost leaks.
Concerning the oil cooler, there is no upgrade. I would only recommend new OEM, and the OEM cooler, despite internet gossip, carries an '03 part number indicating that it has never been "improved" by Ford. Aftermarket coolers are junk, and there are numerous posts about guys who ended up with higher ECT/EOT deltas AFTER the swap than they had before.
The relocation kits are IMO a solution in search of a problem. These kits cost $1,500-$2,500, and there are problems with them over cooling the oil in winter if you live where it gets cold. There are also ECT spikes that can result from these coolers, which can be tuned out, but considering what you're spending on these kits this should not be an issue.
The factory OC does a great job. The issue is not the OC; the issue is the coolant Ford uses, the lack of a coolant filter, and the junk left in the cooling jacket from the casting process. My advice would be to install a coolant filter, change the filter after 1 month, then after 3 months, then do a thorough system flush, refill with a 50/50 mix of distilled water and a CAT EC-1 rated ELC, and then swap the OC. This ensures that you don't just clog a new cooler.
I've got 207k on the clock and swapped the OC once, and it really didn't need it; I was just being cautious. A factory OC kit from Auto Nation runs less than $300 shipped.
hello, which coolant filter should I choose? is the ipr coolant filter ok? Should I install a bypass filter or a inline filter?
The IPR system is really nice and well engineered. I use a bypass style filter from Sinister. Its not going to trap as much stuff as a full flow, but its what I've used for several years now with no issues.
I don't see how or where its going to leak. If it leaks the factory EGR cooler will leak too, as it bolts up to the same places. The full flow coolant filter is a big deal, because you are actually filtering all the coolant instead of just part of it as with most bypass style filters. I'd buy this kit in a heartbeat.
I just did an EGR delete on my 05' F250.
I used one of the EGR delete kits from egrdeletekits.com...........it seemed to fit ok, and the quality of the welds seemed good.
You will need a tuner to turn off you EGR, or you will probably get a check engine light. As far as the coolant filter......I picked up an IPR filter kit. a little pricey, but I've heard they are the best.
Which Tuner do you have? I want to buy an Edge CTS 2 Pro from gearhead with a tune. I additional want to monitor fuel pressure and coolant pressure .
I run an SCT X4. I also have the Torque PRO app on an old smart phone that lets me monitor everything....works really well, and was cheap! As far as fuel pressure, you will need a separate gauge/sender for that.....the motor doesn't have a fuel pressure sensor on it.
Edge tuning is junk. If you like your transmission stay far, far away.
SCT is what all the good tuners use. Custom tunes from Innovative or Gearhead are your best choice.
hello,
ich will order the Edge with a tune from Gearhead. I hope this works :winking:
Like other have said...I've heard that the EDGE tuners eat transmissions. Everyone seems to love the SCT tuners........just something to think about. I'm running the Innovative Diesel tunes.....but even the street, performance, and towing tunes that come with the SCT are really great!!
hm, I only want to order a soft tune at Gearhead (only to clear the ECL), I dont want more power.:|
By the way, that's what you get when you order an EGR kit from the allegedly best US Ford garage in Germany. The "one piece part" is from USA :nerd:
find the mistake:
If you have an android phone you can buy the Torque PRO app for $5, and buy a Bluetooth ODB adapter plug for around $10 on amazon. With the Torque PRO app you can read all of your PID's, do data logging, and also read and clear any fault codes.......much cheaper than buying a tuner if all you want to do it read and clear codes.
You currently have a CEL on, or you're expecting one after the EGR delete? If that's all you want a tuner for I would save my money and see if it sets a CEL first. Early trucks will not set a CEL. '06 may not even be affected.
I would not tune with Edge period. I put one on my truck at 12k miles. By 68k my trans was junk. $3,500 out of pocket (trans warranty only goes to 36k under the "100k powertrain warranty"). SCT tuning and no issues, while making substantially more power. I now only use my Edge as a monitor, for which it works really well. If that's what you want buy the CTS; its a great system. The Torque app works well from what I've heard. You can buy a bluetooth dongle and a used smart phone cheaply enough and mount the phone with a dash mount. You won't get EGT or fuel pressure that way though, which are two important things to monitor, but the cost difference is substantial. Anyway, information if power and all that, and now I've got some more of it.
I like the Edge better for monitoring, so I would buy it.
Which tune should I choose?
Have you a link from the SCT?
Go to Innovative Diesel site....they can sell you the SCT X4 tuner...and also supply you with custom tunes if you want.
I just got an 05 F350 Super Duty and I am very new to this whole thing. It has a lot of aftermarket changes that I need to understand. I have the SCT tuner and I have been playing around with it. I am still trying out all the different engine options that it offers. I have played it safe up till recently and now my truck exhaust doesn't sound the same as it did when I first started. The truck was very fast and had lots of power, now it sounds bad, and does not put out. It has a small coolant leak near the reservoir. I have had every mechanic I know looking for this thing, it is very slow and it is spraying leaving deposits on the hood and down under. I have a coolant filter which I have replaced. I replaced the reservoir its hose, flushed the system and I am still smelling coolant. I have never worked with or owned a Ford Super Duty and I really like this truck!!!! I don't want to loose it to a lack of knowledge and make a mistake driving it or over looking something or neglecting any signs. Were do I start???
1 - 20 of 23 Posts
