1991 E350 conversion van, extended, lifted, raised roof, 129k
Used as a back up vehicle. Maybe 3-4 thousand miles a year. Lowes, nursery, hauling stuff. More lately as I get 22-25mpg which is better than my car.
Used it last night and the radio didn't work. Unusual but everything else was fine
Went to use it today but it wouldn't start. Cranked fast but it was like there was no spark (if it had spark).
The engine wait light would go out but the clicking didn't happen. I turned the key back and forth a few times and the clicking happened. Started up with a jump, high rev, funny sound and then settled into it's hum. Except something smelled funny and there was a white smoke coming from the pipe. I shut it down, popped the hood and black smoke came out. I looked under and could see yellow flames at the back of the engine. Ran in the house and grabbed the dry chem fire extinguiser and sprayed her down. Took the doghouse off and there was small flames so I sprayed more. It appears the glow plug relay or the wires shorted. The housing over the relay is melted. Two wires have the insullation gone. It still starts now but I am reluctant to drive it anywhere.
In the morning it will be cold enough to see if the clicking starts, right now it's 62 and it doesn't click.
Any thoughts what happened and why? I figure I need to replace the GPR and the plastic cover. Not sure where to get the cover or what it's called. Does anyone have a site with instructions to replace the relay? Stick with the Motorcraft or Stancor?
Would appreciate any feedback. I'm not a wrench, just enjoy diesels. Should I replace the easily accessible glow plugs or leave that to a tech.
Charlie
Chambersburg, PA
Charlie
Chambersburg, PA
