Absolutely, we used to help a rancher yearly trail his cattle down from mountain grazing on horseback 17+ miles, then later 13 miles down a secondary highway from the beet fields to his pasture and I had the chemical hand warmers in my gloves and also in the toe of each boot. There's very little cab heat off the back of a horse at 10°. :laugh2:
I should add, I don't know if it's every winter, but our nearest Costco (Billings, MT) carries the chemical warmers in big bulk boxes at a very cheap price. I'd think the Colorado Costco's do too?
I would prefer to have a fuel heater in the truck for most of the country. The main issue with Diesel and cold temps is the cloud point of the fuel. This is when wax in the fuel comes out of solution and starts clogging filters not the fuel line. A fuel heater at the filter will help prevent this. Most fuel today is properly blended for the area you are driving, however, every now and then you hear of an issue. 18 years ago every fall you would see several posts pop up about people with fuel issue. Now if it is a leak monster and causing problems getting rid of it may be the answer. I had a 79 VW Rabbit in Minnesota back in the day. Manual said you could add a gallon of gas per tank of diesel, I used that and additive it worked at -40.
DENNY
DENNY
Yep, that's why when my heater sprung a leak at the plastic plug I opted to buy a new one. Bad part is I drive my '91 so little nowadays it has non winterized fuel in it. I pour in the correct amount of Power Service (antigel formula) but don't know how much to trust it. Years ago there was an out of town box truck pulled over on the east edge of town with tarps all around the outside edges and a portable heater blowing under the entire truck. Those poor guys baby sat that thing for about 3 or 4 days trying to thaw out the diesel.
trying to start my grandads old 1991 f250 but i noticed what i believe to be the timing advancement on the right side (looking from the front) of the injection pump does not move when the throttle is moved, in fact the arm that pushes it bends if the throttle is forced, is that something i can...
I have a 1994 F-350 XL Crew Cab long bed 7.3L idi Turbo manual transmission. And when i bought it the doors were all changed by the previous owner but the harnesses don't match up for the power locks and windows and there are some other electronics that have been "modified" or cut off entirely...
When it's cold (below 40 degrees) I plug my truck in. In the mornings it starts and runs no problem. Problem is when I get to work and it sits for 8 or so hours and the temp doesn't rise or it gets colder thru the day it will start and run for bout 10 seconds then rev up and die. It would take a...
It's a '94 XLT 4-door dually long bed 2WD with a big aux. tank in the bed plumbed to the rear tank (I didn't check exactly how), a 5th wheel, red inside & out with beat-up full-length diamond-plate running boards, front PW (not PM, and I don't remember seeing a PL switch), a slightly mismatched...
Hello I am new to this forum and diesels so sorry if I miss anything. I just purchased my first diesel truck 1990 f250 xlt lariat with a 7.3l non turbo idi with a 170,xxx miles. It also has a manual transmission and f350 axles and suspension. I just bought it about two weeks ago and did my first...
A forum community dedicated to all Ford PowerStroke Diesel owners and enthusiasts. Come join the discussion about PowerStroke performance, modifications, troubleshooting, towing capacity, maintenance, and more!
