The other day I noticed the light on the dash that tells you when the emergency brake in engadged is not working. How do I get to the bulb to check it? Can I just reach up under the dash and find it or do I have to pull the gauge cluster out? If I have to pull the gauge cluster then please explain how.
Also, is there a fuse or a sensor I can check first?
Thanks,
cmichalik
Thanks,
cmichalik
