I have a 01 F-350 that the emergency flashers havent worked in over a year. I use the truck for lawn mowing crew...so at the time when they worked they were used everytime the truck stopped to mow a lawn they would put the emergency flashers on (instead of putting out cones) so after a while they just quit. I checked the bulbs on the lights they are fine and still working. I then checked the flasher fuse (large black relay) And it was fine...not only fine but I bought 2 of them and none of them made a difference. Is there a way to check the switch on the column? Can I replace the switch on the column without any special tools? Any ideas of what it could be?
